NX POINT GRIP
NX POINT GRIP
HI
Anyone who could help me with some source code for compiling a program?
The function should be like this:
The 3D-model part file contains some points.
These points is manually selected, one by one, from the modeling.
The grip program should output the X, Y and Z coordinates drawing table and the lenght betwen points.
Numbering of the points ( P1, P2.. ) shall be the same as the selecting order of the points. (or if grip could select points by it sef automaticly starting from wcs 0,0,0)
the table should look like this
pt x y z r
I don't know if i present problem corectly.
pt x y z r
RE: NX POINT GRIP
I got that GRIP aplication :)
$$ PROGRAM: Point_Coordinates.grs
$$ RELEASE HISTORY :
$$ 25-Jan-10 : Initial submission to library.
$$ Variable Definition
NUMBER/ X(3)
NUMBER/ Y(3)
NUMBER/ Z(3)
NUMBER/ U(3)
NUMBER/ V(3)
NUMBER/ W(3)
NUMBER/ ILEN(3)
NUMBER/ IDECPL
ENTITY/ ENTY
ENTITY/ KSYS
ENTITY/ ENT
ENTITY/ LABELA(500)
STRING/ WVIEW(30)
STRING/ STATION(4,20)
STRING/ NOTA(10,30)
$$ Data Definition
DATA/STATION,'X #@@@.@@@@@@@@@@@@',$
'Y #@@@.@@@@@@@@@@@@',$
'Z #@@@.@@@@@@@@@@@@',$
$$ Active Part Check
IFTHEN/&ACTPRT==1
MESSG/'You don''t have an active part !'
HALT
ENDIF
$$ Read/Setup System Variables
IWLAYER = &WLAYER
IFONT = &FONT
ILWIDTH = &LWIDTH
ITLWID = &TLWID
ITEXTOR = &TEXTOR
ITDENS = &TDENS
ITXJUST = &TXJUST
IVTXJST = &VTXJST
IENSITE = &ENSITE
ICFONT = &CFONT
ICSIZE = &CSIZE
IDSIZE = &IDSIZE
&WLAYER = 201
&FONT = &SOLID
&LWIDTH = &NORMAL
&TLWID = &NORMAL
&TEXTOR = &TXBANG
&TDENS = &NORMAL
&TXJUST = &LEFT
&VTXJST = &TOP
&ENSITE = &MIDC
&CFONT = 1
&CSIZE = .1250
&IDSIZE = .500
ILABELA = 0
IDECPL = 3
&FILARW = 1
&ARIANG=20.
&ASIZE=.2
&TLWID=&THIN
&TEXTOR=&TXBANG
&ENSITE=&MIDC
&TDENS=&THIN
&VTXJST=&TOP
IRED=0
$$ Create Point Coordinate Label
LOOPA: &VWCURS = &ANY
&WCS = &ABS
&DECPL = IDECPL
MASK/2,3
IDENT/'Select Entity',ENT,CURSOR,X,MEMBER,OFF,RESP
JUMP/END:,END:,,RESP
&VWCURS=&ANY
WVIEW=&VWSEL
IFTHEN/ENT<>&NULENT
ITYPE=&TYPE(ENT)
X=MAP/X,FROM,WVIEW,TO,&CURDRW
IFTHEN/ITYPE==2
OBTAIN/ENT,Z
ELSE
OBTAIN/ENT,Z,U
ENDIF
&VWCURS=&WORK
POS/'Locate Label Origin',Y,RESP
JUMP/LOOPA:,LOOPA:,RESP
CREATE/TXT,8
DO/LOOPD:,N,1,3
NOTA(N)=SUBSTR(STATION(N),1,9+IDECPL)
WRITE/8,USING,NOTA(N),Z(N)
LOOPD:
RESET/8
READ/8,USING,STATION(4),NOTA(1)
READ/8,USING,STATION(4),NOTA(2)
READ/8,USING,STATION(4),NOTA(3)
FTERM/TXT,8
ILABELA=ILABELA+1
IFTHEN/Y(1)>X(1)
LABELA(ILABELA)=LABEL/LEFT,Y(1),Y(2),$
ENT,VIEW,WVIEW,NOTA(1..3)
ELSE
LABELA(ILABELA)=LABEL/RIGHT,Y(1),Y(2),$
ENDIF
IRED=IRED+1
PRINT/'P'+ISTR(IRED)
PRINT/NOTA(1)
PRINT/NOTA(2)
PRINT/NOTA(3)
ENDIF
JUMP/LOOPA:
$$ Reinstate System Variables
END: &WLAYER = IWLAYER
&FONT = IFONT
&LWIDTH = ILWIDTH
&TLWID = ITLWID
&TEXTOR = ITEXTOR
&TDENS = ITDENS
&TXJUST = ITXJUST
&VTXJST = IVTXJST
&ENSITE = IENSITE
&CFONT = ICFONT
&CSIZE = ICSIZE
&IDSIZE = IDSIZE
HALT
This Aplication read point position and export to file txt position X Y Z i need to export it to table in drafting. Please someone Help ME
