Step File import
Step File import
Me and my co-worker are trying to import a complex part made in Pro/Engineer into Unigraphics V17 via a Step file format. The conversion process runs without any errors but after the dialog box closes there is no sign of the imported part. Has anyone experienced this problem.
David
David
RE: Step File import
If you need more help send me an e-mail
1.review your ug****.log file, and you can find where the g files are inport.
2. search the ug files by the name form your hard disk.
it must be some where if no error,
mostily it will be the c:\ path
good luck
Look at the log file and do a search for the file names listed in the log file that UG has created.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
