Draft or Loft extruded-cut in SW?
I did some searching for this but didn't come across much information, likely due to the fact that I really don't even know what to call this "process". I used SW version 2006. Hoping to step up to 2010 at some point in the near future but that's for other discussion.
I'm trying to perform an extrude-cut inside a solid body. Without over complicating the description I'm basically trying to perform a cut from one end face of a perfectly round revolving cut, up to a square sketch.
Essentially it's like a regular draft between a round and square sketch on two separate planes, but instead of an extrude I need it to be a cut.
Am I missing something completely obvious here, or is this a feature that is not possible with my variant of the software(new feature on 2010?) I've been working with SW for many years now, but this is the first time I've needed to perform such a cut in an existing solid body.
Any help of tips would be great! Thanks folks!
RE: Draft or Loft extruded-cut in SW?
http://
thanks!
"a point I missed, too"
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Info and help is much appreciated. I'd likely still be looking for it had I not asked here.
