AUTOCAD>IGES
AUTOCAD>IGES
AUTOCAD>IGES
Can AutoCAD export IGES files? If so how?
RE: AUTOCAD>IGES
Just type in "IGESOUT".
BU
RE: AUTOCAD>IGES
Hi, I need to have a AutoCAD 3-d solid drawing saved to an IGES or STEP file but am having the same problem as Andrew299. When I use the IGESOUT it says it is an unknown comand. I have AutoCad 2000, is this feature available on only on the newer versions?
Thanks for your time,
-nick
RE: AUTOCAD>IGES
I apologize, Autodesk started making you pay for IGES capabilities with AutoCAD 14 I believe. We use AutoCAD Mechanical, so it is built in.
"Everybody is ignorant, only on different subjects." — Will Rogers
