CENTRIFUGAL COMPRESSOR
DEAR COLLEAGUES,
WILL YOU PLEASE EXPLAIN FOLLOWING THREAD.
CAN WE RUN CENTRIFUGAL COMPRESSOR BY THROTTLING SUCTION AND DISCHARGE VALVES
WITH REGARD
SAFDAR TOOR
WITH REGARD
SAFDAR TOOR
RE: CENTRIFUGAL COMPRESSOR
In either case, you need to ensure you remain within the compressor's allowable operating envelope for flow, head, pressures, etc.
In case you throttle the compressor discharge, beware of going below the recommended min flow, a safety relief valve bypassing back to the supply should be installed to avoid damage to the compressor...and in any case recirculation cannot be permanent due to overheating.
Cheers,
