Hole Wizard Crashing Trouble
Hey guys, just joined to try and get to the bottom of this.
Im using Solidworks 2010 student edition. I just recently noticed that when I try to use hole wizard I get some issues. Firstly, I dont get any options for the hole. I can only select "hole type" "standard:" and "type:" are grayed out. Im pretty sure there are other options that dont appear as well.
Also, if I click on any hole type and then attempt to click "straight tap" Solidworks will crash.
Ive repaired and have the same issue. I reinstalled and have the same issue. I changed the directors toolbox/hole wizard looks in to C:\solidworks Data(2)
Im stumped here, any ideas?
RE: Hole Wizard Crashing Trouble
Try the uninstall procedures outlined here ... especially the batch files.
https://forum.solidworks.com/docs/DOC-1014
If that doesn't work, it may be easier to reformat and start fresh.
I assume you are using a legit student version?
