Aluminium Extrusion slotted Framing sources UK
Hello all,
I'm searching for a UK source for Aluminium T-slotted frame systems that will allow me to do the following :-
Use a square section of 30x30mm with a variety of profiles.
Buy off the peg connectots, fasteners, gussets and bracing etc.
A major requirement is for connectors that can pivot or be angled to lots of different angles, as well as the usual straight and 90 angle connectors.
I've found one or two companies that appear to supply what I'm after but they are overseas based and I'd prefer to source from the UK.
Here's the kind of thing I mean (note the pivot connectors which are essential to my needs) :-
https:/ /www.frami ngtech.com /shop/prod ucts.php?F TPJ0830&am p;cPath=8_ 63&osC sid=05s8tg jl582ope6n o9hfrkrgl3
I've so far contacted several UK companies who supply framing systems but all so far can only supply 90 degree or straight connectors.
Thanks in advance.
Dan
https:/
Thanks in advance.
Dan
RE: Aluminium Extrusion slotted Framing sources UK
Most popular in Europe:
http://www.item24.com/en/
ht
http://www.mk-group.com/en/home.html
