Journal to list reference sets in a part
Is there any way to create a list of reference sets in a part?
We are in the process of taking ~2000 models from a customer and reformatting them to our standards which requires replacing the existing reference sets with our own along with a few other cleaning operations. I have been able to automate most of the cleaning operations using a journal file, but as of yet I cannot handle reference sets. Our current method requires going through each part and manually deleting each refernece set, then adding at least one reference set for the solid.
I have gone though the .net api reference as far as I can follow but cant figure out where to pull a list of reference sets from a part. I have found how to add and removed them and how to add items to them, but nothing to list them.
referenceSet1 = workPart.CreateReferenceSet()
referenceSet1.SetName("model")
referenceSet1.AddObjectsToReferenceSet(components1)
workPart.DeleteReferenceSet(referenceSet1)
Any suggestions would be gratefully appreciated.
UG NX 6.0.4.3
RE: Journal to list reference sets in a part
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Is there a way to list each reference set in a detail part or just delete all existing ones, which our ultimate goal?
UG NX 6.0.4.3
The second program simply reports the reference sets for all components. This has been written more recently and is in VB. I have also compiled it and signed it.
Frank Swinkels
The programs are similar to what I was looking for but from looking at them i found the CycleObjsInPart function which has allowed me to accomplish what I was looking for. Thanks
Below is what i cam up with:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UF.UFObj
imports nxopen.utilities
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim WorkPart As Part = theSession.Parts.Work
Dim TheUFsession As UFSession = UFSession.GetUFSession()
Dim NULLTAG As Tag = NXOpen.Tag.Null
Dim objectTag As Tag = NXOpen.Tag.Null
theUfSession.Obj.CycleObjsInPart(workpart.Tag, NXOpen.UF.UFConstants.UF_reference_set_type, objectTag)
Do
Dim myrefset As referenceset = Nothing
Dim myObject As NXObject = Nothing
myObject = NXObjectManager.Get(objectTag)
myrefset = CType(myObject, referenceset)
MsgBox("Name = " & myrefset.name)
theUfSession.Obj.CycleObjsInPart(workPart.Tag, NXOpen.UF.UFConstants.UF_reference_set_type, objectTag)
Loop While objectTag <> NULLTAG
End Sub
End Module
UG NX 6.0.4.3
