normal datum plane
normal datum plane
I'm trying to create a datum plane and I want it to be normal to a plane and through a curve which resides on that plane. The curve is a straight line that was sketched. I can't seem to do this by just selecting the curve and the plane. I've tried Inferred, Curves and Points, and probably a few others with no success. In the past I've created a Line at one of the endpoints of the line and normal to the plane, then created the new datum plane using Two Lines, but that just seems like a work around for something that should be simple. Is there a way to do this that I'm missing or is that my only option?
Mike
RE: normal datum plane
Cowski I will hoist a couple in your honor thisa Sunday!
Mike
