Anyone know of a prefabbed TVS array with screw terminals?
I've got a TTL level digital input card that's started popping channels. I suspect a wiring fault in our cabling or test unit is temporarily tossing 24VAC onto the input line which the input card can't hold off.
So, I'm looking for a protection solution somewhere this side of full-blown isolation ($30x18 channels is a little more than I'd like to spend + I have limited room in the system).
It seems to me an ideal solution would be an array of zeners like in a TVS diode array. I just need the voltage from any intermittent shorts held off the input pins long enough to blow the 1A quick-blow fuse on the 24VAC line. I've found IC's that should work for this for $2-3, but I'd rather not spin a PCB if I don't have to.
Does anyone know of a PCB or DIN-rail mounted solution for a problem like this for less than $300 or so?
RE: Anyone know of a prefabbed TVS array with screw terminals?
The SCR is across the line and its gate is connected to a simple little circuit designed to trigger the SCR when the voltage exceeds the adjustable limit. The SCR dead-shorts the line when triggered. The circuit typically requires some careful attention to bypassing to prevent false triggers.
