cleaning of flux residue of SAC305
Does anyone know of an effective method to clean the flux residue of a SAC305 solder joint? I need to totally remove the residue in order to ensure no delamination effect of the silicone rubber layer and the solder joint.
Thank you!
Thank you!
Best regards,
ct
RE: cleaning of flux residue of SAC305
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
Here a link to one of many companies that supply the flux and a cleaner. For testing you may want to look at their soldering masks.
http://www.qualitek.com/flux_remover.html
