Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...On your site I feel quite confident that the contacts and feedback will make my life a little less hectic..."
Geography
nanoman40 (Electrical)
20 Jan 11 22:50
I am looking for a high temperature Polyethylene (HDPE, UHMW, PEX,  HDXLPE or other high hydrogen containing material).
4.55" OD x 3.90" ID or ~0.325 thick (could be extruded, made with "welded" sheet or machined from bar)
Will be used in a vertical orientation.
Non-structural static application (needs only to support its own weight and NO differential pressure)
Environment: Dry Nitrogen at 1 Atm, contained within a titanium or aluminum tube.
 Temperature:  Normal:   120°F
               Abnormal  260°F (127°C) for up to 35 days
Cracking  / Splitting is allowed
Any color
I would greatly appreciate any input on any material satisfying the above conditions?
patprimmer (Publican)
21 Jan 11 3:30
Any PE will struggle even supporting its own weight at 127 deg C
Polypropylene should do it.
Nylon might do even better but is probably over the top
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Demon3 (Materials)
21 Jan 11 10:19
If you need a hydrocarbon polymer then PP is a great choice. If you needed higher temperature then COC (Topas) would work (much more expensive though).
Now I read your post more carefully, why not PE? It says it's contained in a metal tube so it wouldn't matter if it's a bit soft.
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
Close Box
Join Eng-Tips® Today!
Join Us             Close
