3d sketch & vertical / horizontal dims
Is there a way to have horizontal and vertical dimensions between holes that are positioned with a 3D sketch? Currently I keep getting an angled dimension between the points.
Thanks PD
Thanks PD
www.phoenixdyno.com
Home of the world's most accurate and repeatable dynamometers, dynamometer accessories, and data acquisition & control software.
RE: 3d sketch & vertical / horizontal dims
I know that not exactly what you are asking for, but it is an easy translation between Baseline & Chain style dimensions
-Dustin
Professional Engineer
Pretty good with SolidWorks
3D sketches get very complicated very quickly because like ShaggyPE said: You are using construction geometry to lay everything out.
Think about the problem, and if you can create a plane then make a 2D sketch, it will make your life easier in the long run.
www.phoenixdyno.com
StrykerTECH Engineering Staff
Milwaukee, WI
http://www.stryker-tech.com/
