Load Control
Load Control
I am trying to model a test performed using a servo hydraulic machine and I need to be able to control Abacus Standard using "Load Control". Basically I am unloading a specimen to ~70N and then reloading, is there any easy way of doing this?
RE: Load Control
RE: Load Control
you can run a test-model where you apply a predefined displacemment in time and large enough to create force of 70 N. Check the time-history of the force-displacement and see what displacement needed for a force of 70 N
Stig
RE: Load Control
Rob Stupplebeen
RE: Load Control
You can use sensor outup plus uamp subroutine.
Barten
