nut for 6" threaded rod
Can anyone give me any dimensional information or a place to look for that information for a nut that would be used on a 6" diameter threaded rod?....thanks in advance
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: nut for 6" threaded rod
Bob G.
But in college (many years ago) I worked in the fastener department of a large company. One day we got such a nut in for a customer and it weighed about 250 lbs if I remember. It was used on a bridge.
Google should be helpful.
Long ago, I worked in a shop and one of the tools in the toolbox was a 60" pipe wrench. The unique thing about it was that it was BENT.
The story behind that was that the hydraulic cylinders on trackhoes had ends that thread off, which was normally a job involving a hammer and chisel, much time, and application of select words. (The ends had little notches around, not flat sides like a nut.) Someone got the bright idea of buying this giant pipe wrench to speed up the process, and they then used another trackhoe to turn it. The wrench had a gentle bend to the side.
Anyway, this website:
http://
shows "EN-Series Bolts and Nuts" in sizes up to 6"/150mm.
A number of the DIN thread standards address threads over 150mm, so presumably nuts are addressed somewhere also.
Mike Halloran
Pembroke Pines, FL, USA
