Error Opening File in NX5
Similar to a previous post I cannot open a UG part.
UG Message see attachment:
Anybody any idea what could be wrong?
Already contacted Siemens Helpdesk but they couldn't open this one eather...
They are investigating it furhter, but you never know that somebody knows here a bit more.
Best regards,
Pascal,
NX5.04+TC2007 (GM Toolkit) / NX7.5 native
RE: Error Opening File in NX5
Was the file translated from another system, or is this a native NX part?
... allcatparts are done in catia v5.
maybe you try to import hte file into a NX new file.
reg.
No it was Translated from CATIA.
I see in the naming that "catpart" so I am pretty sure is CATIA V5.
The "other" side won't move because they say there data is not corrupt, but I think not.
Thnks
Best regards,
Pascal,
Thanks for the tip,
but same result sad
I will request the CATIA Data to export/import them myself.
then hopefully I can do better than them.
if the Helpdesk or I find anything I let you know
Best regards,
Pascal,
I have often troble with the ... allcatpart.
I most case its a file memory problem during translation.
Second thing you can try to use the nx commandline utility:
 ug_inspect
here is a little script
IF NOT DEFINED  UGII_BASE_DIR GOTO:NOTSET
TITLE Running UG_INSPECT
Echo Running UG_INSPECT.exe
Echo Please Wait...
Echo.
set thisScriptPath=%~dp0
set corrupt=corruptFiles.txt
set logDirectory=ugInspectResults
set ugInspectCommand=%UGII_BASE_DIR%\UGII\ug_inspect.exe
:: create a directory for the results information if it does not exist
IF NOT EXIST %logDirectory% mkdir %logDirectory%
:: show me only the files with .prt extension and nothing else
:: then pass each file it finds to the utility
for /F %%f in ('dir /b *.prt') Do CALL :RUN_UG_INSPECT %%f
    :: I'm done cycling through, quit the application
    GOTO:QUIT
:RUN_UG_INSPECT
    :: set the incoming file argument as a easy to read variable
    set fileName=%*
    :: check for known corruptions
   :: %ugInspectCommand% %fileName% >> %logDirectory%\%fileName%_Results.txt
    :: To display the help options of ug_inspect
    ::%ugInspectCommand% -help >> ug_inspect_HELP.txt
    ::%ugInspectCommand% -rm %fileName% >> %logDirectory%\%fileName%_RecordManagerPartition.txt
    ::%ugInspectCommand% -cmod %fileName% >> %logDirectory%\%fileName%_cmod.txt
    ::%ugInspectCommand% -ess %fileName% >> %logDirectory%\%fileName%_ExpressionPartition.txt
    ::%ugInspectCommand% -occ %fileName% >> %logDirectory%\%fileName%_occurrencesPartition.txt
    ::%ugInspectCommand% -path %fileName% >> %logDirectory%\%fileName%_pathPartition.txt
    ::%ugInspectCommand% -ps %fileName% >> %logDirectory%\%fileName%_parasolidPartition.txt
    ::%ugInspectCommand% -full %fileName% >> %logDirectory%\%fileName%_allPartitions.txt
    ::%ugInspectCommand% -trace %fileName% >> %logDirectory%\%fileName%_tracingInfo.txt
    ::%ugInspectCommand% -cookies %fileName% >> %logDirectory%\%fileName%_objectID.txt
    ::%ugInspectCommand% -refs %fileName% >> %logDirectory%\%fileName%_recentReference.txt
    ::%ugInspectCommand% -all_refs %fileName% >> %logDirectory%\%fileName%_allReference.txt
    :: Look for all known corruptions
    ::%ugInspectCommand% -scan %fileName% >> %logDirectory%\%fileName%_corruptions.txt
    :: use this option for pre version 12 files
    %ugInspectCommand% -extract_all %fileName% >> %logDirectory%\%fileName%_extractAll.txt
    :: extracts parasolid transmit files
    ::%ugInspectCommand% -extract %fileName% >> %logDirectory%\%fileName%_extractParasolidInfo.txt
    ::%ugInspectCommand% -release %fileName% >> %logDirectory%\%fileName%_releaseInfo.txt
    GOTO:EOF
:: If a variable is not set, tell the user then quit
:NOTSET
    echo.
    echo 'UGII_BASE_DIR' is not set
    echo Please set this variable, then run this script again
    echo.
    GOTO:QUIT
:QUIT
   :: reset the windows title to default
   title %comspec%
   ECHO.
Thanks uwam2ie for this,
i am a complete dummy in this mather so i try to struggle to have this script running.
Any tips or Scripts for dummies?
Grtz.
Best regards,
Pascal,
