Foundation Control
Foundation Control
Hi 1000$ for the correct answer:)
I d like to understand better the chapter 7.5.5.2 & 7.5.5.3 about foundations control before erection.
For 7.5.5.2 should we check only the contour?????It seems clear.
For 7.5.5.3 it talks about "specified high point" What does it mean?Is it an external point to refer to?
shall we check only the contour?Or the slope to?It is not very clear.
Thank you in advance
RE: Foundation Control
I m implementing a work instruction for the foundation check according to EN 14015 & API 650 for my company.
I like the center best -- easy for the Vac Truck to suck out the last liquid when cleaning the tank for entry.
