Seeking Program for Effective Section Prop Cold Formed Steel ANSI
I am looking for a program that can accurately calculate section properties for Cold formed Steel with ANSI effective width method. I have tried AutoCAD, Solidworks, ShapeDesigner, ProE, ShapeBuilder and alot of more. However, none of those software has the capability to do so. Can some professionals help me out? I will appreciate from head to toe.
RE: Seeking Program for Effective Section Prop Cold Formed Steel ANSI
http://www.devcosoftware.com/aisiwin.html
Neffers
http://www.rsgsoftware.com/
Neffers
at
http://www.iesweb.com/products/shapebuilder/
Please look that the image I supplied. All I need is a tool to calculate the effective Ixx, Sxx in positive bending (top in compression) and negative bending (bottom in compression).
Command: MASSPROP
Select objects: 1 found
Select objects:
---------------- REGIONS ----------------
Area: 6.7068
Perimeter: 10.7650
Bounding box: X: 3.6835 -- 7.1069
Y: 2.6424 -- 4.6015
Centroid: X: 5.3952
Y: 3.6219
Moments of inertia: X: 90.1286
Y: 201.7705
Product of inertia: XY: 131.0579
Radii of gyration: X: 3.6658
Y: 5.4849
Principal moments and X-Y directions about centroid:
I: 2.1451 along [1.0000 0.0000]
J: 6.5501 along [0.0000 1.0000]
iv
Thanks for the reply. I am planning to get the CFS. I just contacted them. Seems like they are going to release a new version of CFS to allow the import of DXF file which is very beneficial to me.
ANY FOOL CAN DESIGN A STRUCTURE. IT TAKES AN ENGINEER TO DESIGN A CONNECTION."
