Taper bearing - shaft fit
Hello chaps,
again another dump bearing question from this bearing newbie.
I'm in the process of determining the fit of taper bearing on it's shaft. The application is a truck wheel bearing, two bearing, back to back.
On SKF.com taper bearing don't seem to be mentioned separately. I gues the 'radial table' applies, and thus a g6 fit would follow(please see the middle of the page).
http://www .skf.com/p ortal/skf/ home/produ cts?newlin k=1_0_74&a mp;lang=en &mainc atalogue=1
This would result in a transition fit because SKF taper bearings have -25mu tolerance on the inner bore, pls see link.
h ttp://www. skf.com/sk f/productc atalogue/j sp/viewers /tableView er.jsp?tab leName=1_0 tt10.tab&a mp;maincat alogue=1&a mp;lang=en
Now, this makes me wonder, isn't a taper bearing alway 'loose'?
Furthermore when on the NTN website they DO mentioned a specific table for taper bearings, which does indeed has a loose fit, please check table 7.7(1) on the pdf.
http://www.ntnamerica.com/pdf/2200/brgfits.pdf
Again, any input is highly appreciated.
http://www
h
RE: Taper bearing - shaft fit
I'm pretty sure the Timken application notes go through the analysis for a pair of wheel bearings, or at least my 30 year old paper copy does.
Cheers
Greg Locock
