Resulting forces in the Z axis.
Please can someone help me in the solution for calculating the resulting force in the Z axis. attached is the situation (rigging diagram) specifiaclly the top slings are in question. the end elevation shows them to have an angle 65-69deg.interior angle and in the side elevation 72-74deg. interior angle. Basically what is the resulting force acting on the top slings given the two angles their at?
Using a force off 75Te for the object itself.
thanks.
thanks.
RE: Resulting forces in the Z axis.
I agree the question is PDB (PrettyDamnBasic) ...
let the load in the sling = P
[do all the slings have the same load ?]
calc components of P in the 3 axes (yes?)
sum the (presumably)Z components to equal the applied load
solve of P,
and it's components.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
you've got 4 unknowns (the load in each sling) and 6 equations of equilibrium, so it does solve. it is possible that the solution may be impractical, if one of the slings is required to carry a -ve load.
an important practical point, the CG of the load needs to be on the line of action of the lift.
i understand the basics but am i making this problem harded than it is? i guess i am ....
http://www.maximumreach.com/software.htm
Patricia Lougheed
i dont understand how one sling may carry a -ve load?
Because riggers carry sets of matched length slings, the load will go off level to get the c/g under the line of action. The riggers will often insert some shackles in the slings on the high side to roughly even out the load.
If the load has to be maintained level, the riggers will likely use a different, and more adjustable rigging.
Tobalcane
"If you avoid failure, you also avoid success."
"Luck is where preparation meets opportunity"
Tobalcane
it was a bigger difference when i started, got smaller as i worked on it some more ;)
i (now) think the problem is redundant (the lower portion has 4 unknowns and only three equations). You can still solve this with other methods (i like the unit force method, but there are probably other methods better suited to this problem).
the slings can't carry -ve load, that's what i meant by "impractical solution" ... the math will quite happily put a -ve load on a sling, but you can't in real life.
btw, your other angles are a little off ... add a decimal place or two.
Unless I am missing something this problem looks trivially simple. So please correct me if my simple analysis doesn't stack up.
First, look at the bottom set of straps. You can easily draw a vector diagram from the left side view forcing the the vertical resultant to 1/2 the load. The length of the vector would be in true length.
Now for the upper region, you can do the same, but the vectors are not not shown in true form so they would have to be rotated to get the answer.
If I can do it graphically, it can be done analytically, easily.
therefore Pz1 is relatd to Pz4, and Pz3 to Pz2 [geometry]. then sum moments in the elevation plane and the end elevation, and it should be statically determinate.
While this approach may be mathematically correct, it doesn't square with the physics. Of the 3 tri-vectors,I find that only one has 3 tensions and therefore it is the ONLY solution compatible with the physics and the mathematics.
When I look at the 3 equations with 4 unknowns,I call one unknown 0 and solve for the others. If you do this 4 times each with a different choice, you will get only one answer that squares with the physics, namely three positive (tensions) values. I submit that that is the answer.
As for the lower support, the problem is mathematically tenable, since there are enough equations to match the unknowns.
having said that i noticed that one of trhe zero cases gave a negative load, but this is ok 'cause when you avaerage the different cases all the sling loads are positive.
Having said that, the lower portion solves easily, and this provided the Fz (& Fx) reactions for the upper portion, so all you need is the Fy component, again this solves easily.
That's my point. It is NOT ok. You have no license to average since it will give meaningless answers.
Any 4x3 linear set can have an arbitrary "solution set" by assigning an arbitrarily value to one unknown.
Does that make the answer correct?
Does the part your lifting stay horizontal if you have the slings as shown on your diagram? if so I may have a solution.
regards
desertfox
The only way to solve this I think is by using compatibility of deformation, so you need to know about the sling material elasticity and their cross sectional area's, have a look at this example, whilst I realise its only a 2D example I thinks its the way to solve your problem.
I have managed to calculate from your post the individual angles coming from the single hook down using trig but I am unsure about the two views you uploaded as to whether there drawn in first or 3rd angle projection, also what is the horizontal distance between the top slings in the side elevation? I have managed to calculate these using the 72 and 74 degree angles.
on the link go to page 49 example 2.9
http://boo
indeterminate+force+systems&source=bl&ots=Gxv5jW8GmL&
sig=RHqYvYpXWUMfv6_pAzu2l27q47I&hl=en&ei=mZE8TYzMGdC
whQewytmNCg&sa=X&oi=book_result&ct=result&resnum=1&sqi
=2&ved=0CBYQ6AEwAA#v=onepage&q=statically%20
indeterminate%20
force%20systems&f=false
desertfox
Hate to belabor the point, but, in general, , maybe a more reasonable solution would be to minimize the energy stored in the slings.
So of the infinity of solutions to the 4X3 set, only one minimizes the energy stored.
but we agree that the lower portion is statically determinate ('cause the slings are inclined in one plane only) ...
surprised that 72 and 74 deg worked, i needed 72.5 deg to balance the x components ...
I'll give you that one.
Further to my last post I have calculated the tension in each leg using the theory above these are the magnitude's :-
20.8559 Te
22.15143 Te
21.7367 Te
20.4915 Te
I have checked these obtain equilibrium and they do to within 0.5 Te due to rounding off.
I will post a full solution on friday when I get to my main compiutor.
desertfox
tan74*3687 = tan72.54*4044
my lower reactions (based on 74 and 72.54) are ...
P1 = 20.6Te ... P1z = 19.86Te
P2 = 25.6Te ... P2z = 24.61Te
P3 = 23.5Te ... P3z = 22.43Te
P4 = 19.0Te ... P4z = 18.10Te
P1 and P2 are on the 74 deg slings
P3 and P4 are on the 72.54deg slings
P1 and P4 are on the 65 deg slings
P2 and P3 are on the 69 deg slings
did you use the same method as desertfox?
thanks for the effort looking into this.
x- and z- compoents are related to one another
then sum Mz about pt3 ... relates P1x and P4x
similarly you can relate P3x and P2x
[i'm not going to give you the whole answer, just enough to help you ...]
then these allow you to relate P1z to P4z (and P3z to P2z)
then, using you EE view, sum Mx about pt2 relates P1z and P4z to the applied load, so you can now determine P1z (and P4z). similarly sum Mx about pt1 gives you P2z and P3z.
btw, any comment on my posts about angles ?
182,167,207,226
Correction by 10 factor.
Should read:
18.2,16.7,20.7,22.6
I think the whole thing has been over complicated:
Take moments to get the distribution of vertcical forces along one axis.
Take moments in the perpendicular direction to get the distribution of these two forces, giving you a vertical force at each corner.
Resolve along the cable to get the axial force in the cable.
Load Mass 75t
Total vertical force 735 kN
Distribution along long axis 384, 351 kN
Distribution along short axis 213, 172, 194, 157 kN
Resolve along cable 224, 179, 204, 163 kN
(My FEA program gives the same answer).
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Resolve along top cable 240, 197, 218, 180 kN
Doug Jenkins
Resolve along top cable 240, 197, 218, 180 kN"
But the top cables are indeterminate. How does your FEA do it?
I don't think that they are (but I suppose I'd better read the thread before getting definite about that)
The same way it does any other problem, determinate or indeterminate, by solving for equilibrium and strain compatibility. I just put the problem in as shown in the sketch and got the same answers as the the simple analysis (+- a kN or two, probably due to the angles being rounded to two figures).
Doug Jenkins
Doug Jenkins
4 vector forces passing thru a single point adding to only the z component means 4 unknowns and 3 equations, one for each direction; this makes it indeterminate.
Doug Jenkins
my answer is the same, near enough 'cause you used the angles provided.
zeke, the upper cables are determinate 'cause the only load to be determined is the lateral load since the lower cable loads define everything else.
Forget the lower half.
If I take this contraption and look a the external loads, I find 750T weight at the mass and 750 T at the upper hook in a straight line.
Now the 4 cable force vectors, whose directions are known, emanating from the upper tie, added vectorially, equal that force vector.
Only 3 equations can get you there, but you have 4 unknown vector forces.
That is the problem.
BTW, I did the problem, minimizing the energy and get answers very close to both of you, but I disagree with any method that does not use minimization of energy as a 4th criterion.
Rb, as a matter of fact you have already shown that by cutting one of the upper ties (there are 2 3tie solutions) you can get a valid solution.
Does that not offer evidence of the indeterminate nature of the problem.
then the upper slings Y- and Z- components are defined for the upper slings (consider the Fz balance at the transition, as an example) and the only thing that changes in the upper slings is that there is an X-component. This is carried by the strut between the two slings at an end, therefore equal and opposite forces are applied. therefore this component can be determined by static equilibrium.
You finally got me. The error I made is in saying that the upper cable vectors meet only 3 conditions for equilibrium.
In fact the struts preclude that assumption and 2 pairs of vectors are held at angles determined by the strut and cable geometry thus guaranteeing a unique solution.
And BTW, the upper set of tensions are greater than the lower ones by a factor equal to the cosine of the angles between the conmtact pairs.
My solutions are:
Lower:18.2,16.7,20.7,22.6
Upper:20.0,18.4,22.1,24.1
units in Te
On the question of why the upper four cables are determinate when there is a stable condition with only three cables; the three cable stable condition has a different geometry to the four cable stable condition, so if we cut one of the four cables it is not stable until it has undergone a large movement.
Doug Jenkins
"Te, te
non-standard symbols for the tonne (metric ton), used by some engineers in the UK. The only proper symbol for the tonne is t. If it is necessary to distinguish the tonne from the British Imperial ton, use tn for the British unit. "
http://www.unc.edu/~rowlett/units/dictT.html
Doug Jenkins
"has a maximum take-off weight of 107.5 metric tons"
so just as kg is used for weight by the general public, maybe the OP meant tonne.f (= 9810N?, but a "valid" force) rather than 1000kg (mass)
RB1957; Yes the angles are rounded. sorry should have made them to one d.p.
Te as i used for reference as one metric tonne (1000kg).
the solutions are interesting ill take my time to read the posts again. Great look from a different point of view with the solutions. thanks.
My solution as promised, I have only calculated the forces in the top slings using the theory of the link I posted last week.
desertfox
The method indeed conserves energy and vertical force equilibrium but does NOT satisfy horizontal force equilibrium.
As an example take the classical picture frame problem where the frame is supported by a nail at the top with two strings attached to the frame at different angles. You will get incorrect answers using this method, since you cannot satisfy horizontal equilibrium. As an extreme example, let one of the strings be vertical, then by classical methods it should take the ENTIRE weight of the frame and the other string at a an acute would take NO force. By the method above, the tensions would be quite different.
Would you neglect the above method used even if just for an indication of the forces?
Just post your solution with full workings out, then we can see where I am incorrect.
desertfox
I would, if it couldn't pass muster like handling the simple picture frame problem I posed. How much confidence could you have in a solution that gives a different answer to a simple problem whose solution is well known.
"Just post your solution with full workings out, then we can see where I am incorrect."
Desertfox,
All I have to show is that it leads to incorrect results for a simple well-known problem. I gave a good example, but if that is not enough, I will show a more concrete simple example subsequently.
I would hope to see someone else weigh in with their view of this. Rb1957,IDS, where are you?
All you need to show is your solution to the original problem and how it balances out, no need to go to the trouble of calculating fresh examples, why not post the workings out for your answers you gave.
The solution is so well known that everyone as different answers, in addition my answers are as close as any others here, however I cannot tell from your post which tension is in which cable which if you post your workings and a diagram I can check the equilibruim for myself.
I'll have another look at the original problem and see if I have anything to add.
Doug Jenkins
Just comparing my results with that of IDS the % difference's are as follows:-
for force 1 = 3.7%
force 2 = 9.4%
force 3 = 2.1%
force 4 = 10.45%
Given that these sets of results have been calculated by two different methods I would say there very good bearing in mind I calculated the angles and geometry of the top slings and used the method given in the link.
I'll standby my answers for the forces in the slings as an estimate, as all the other answers are just that, having calculated any forces for lifting devices, one automatically puts a good safety factor onto them.
I have re-done my calculation assuming the given dimensions and the larger of the two angles at each level are exact (see attached spreadsheet for detailed calcs and diagram).
I now get:
Resultant Force, Strand7 Results, Convert to tonne-force
Fi = Vi/sin(NIP) 235.91 kN, 235.91 kN, 24.07 t-force
Fj = Vj/sin(NJP) 216.64 kN, 216.64 kN, 22.11 t-force
Fk = Vk/sin(NKP) 180.06 kN, 180.06 kN, 18.37 t-force
Fl = Vl/sin(NLP) 196.16 kN, 196.16 kN, 20.02 t-force
The forces are now in exact agreement with the FEA results (with corrected geometry), and very close to zekeman's.
As for the best way to do it in practice, I'd suggest doing the FEA or frame analysis (which apart from anything else is the easiest way to get the geometry), then do a "hand" (i.e. spreadsheet) calc to make sure it is in equilibrium.
Doug Jenkins
If the vertical deflections at each corner are not the same then the component being lifted cannot remain horizontal, which Bert2 stated it did remain horizontal during lift.
Good spreadsheet though.
desertfox
The deflections are small, so the load will stay very close to horizontal.
The only way the deflections would be the same is if the sling stiffness was proportional to the vertical load, but that wouldn't change the loads in each sling, because it is statically determinate.
Doug Jenkins
Yes the idea is that all the slings have the same area and modulus.
desertfox
It is clear that for some problems, like this, the difference is huge.
the problem is statically determinate, so you don't need energy methods to solve it.
please, done and dusted, no?
huge thanks for the time looking into this and the two different solutions.
If i was looking at it in a general case i would assume zero deflection in the slings.
to get a guide on the loads applied.
you could take it to the next level as zekeman has shown but in my case i dont need such an in depth approach-good even though it is.
notice though if you didn't have the parallel slings the problem would be indeterminate and you'd have to include deflections as a criteria for developing your loads.
the important thing to take from this is drawing a free body diagram will take you a long way towards solving the problem.
The problem is definitely statically determinate even if the object being lifted is rigid and the slings are inelastic. If any of the sling lengths was to be changed slightly the geometry of the problem would change ie the sling lengths have been adjusted to produce the geometry shown (lower slings vertical in end view.)
Engineering is the art of creating things you need, from things you can get.
In hindsight you are probably right, but, save for the special geometry of the bottom slings, you would be looking at a messy problem. So what happened, on first blush the problem looks easy. On second blush, maybe indeterminate, and finally got it right on the 3rd look.
Personally, my performance was pretty shoddy, especially after everyone was screaming that the problem was determinate. I was hung up on the upper sling arrangement and disregarded the link connections to the lower half. After doing problems for over 50 years, I should know better.
In any event the thread was probably useful as an exercise in statics and determinate and indeterminate structures.
