Regarding part clean up
Hi All,
Good morning.
Can anyone help me out related with part clean up issue?
I have one part file.In this part file so much unused data like surfaces, points, lines in that file.I want to clean that data from file.
These data I have used as a reference.Now this data dont have any link with final model.
Now I want to delete that data.
I have tried it with part clean up option but it didnt work.
Please suggest.
Amar Halake
Good morning.
Please suggest.
Amar Halake
RE: Regarding part clean up
Part cleanup will not delete unused entities in a file. You will have to go through layer by layer, view by view to delete the unused entities that you don't want.
When you are done, then run part cleanup.
Ben Loosli
choose FILE--> EXPORT--> PART
Near the bottom of the dialog box, you will see "Feature Parameters"
choosing "remove parameters" will give you a dumb solid body
choose "Retain internal parameters" and you will keep all parameters related to the part
choose "retain all parameters" will do exactly what it says.
I use this option to extract dumb solids from messy files all the time.
JAY
NX 6.0.5.3
Alternatively, you can switch the part navigator out of timestamp mode (through right click menu) and have a look at the 'unused items' folder. Some care will need to be taken here though, sometimes an 'unused item' is still referenced in some way. Deleting entries willy-nilly could cause a problem.
It works for me.
Thank you very much.
Amar
