Need a version of Visual Urban (HY-22) or similar that runs on 64 bit
I just discovered that the FHWA's old "Visual Urban (HY-22) Urban Drainage Design Program" doesn't run on 64 bit machines. (or at least the installer won't)
Anybody got something else they've been using that's free? I'd rather not shell out the cash for StormCAD or similar if I can help it, for small projects.
Thanks in advance.
Thanks in advance.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
RE: Need a version of Visual Urban (HY-22) or similar that runs on 64 bit
http://
And it worked. It's supposedly a permanent work-around for all old legacy software, basically creates a complete installation of Windows XP in a little window that you can pull up and "install" software in, complete with it's own desktop interface. Sorta like VPNing in to another computer, except the computer is a virtual computer on your own PC.
I'm still interested in knowing if anyone else has a free / government supported software recommendation to run gutter spread calcs though.
Gutter Spread: T = [(Qn)/(KuSx1.67SL0.5)]0.375
No charge.
I'm an experienced XP-SWMM user, and might crack out EPA-SWMM one day if I'm so inclined, but sometimes you need something simple.
I have been able to load a 32 bit software program into Windows 7 by installing it in the 32 bit program file directory. They will default to the 64 bit program files when trying to install. I just copied it from the 64 bit directory into the 32 bit directory and erased the 64 bit directory files and it worked. Besure to change the installed shortcut to the right directory. In Windows 7 I think Program Files (x86) is the 64 bit directory and Program Files is the 32 bit directory. If it installs I would double check your answers against old work to make sure it is indeed giving you the correct answer.
Yes you can complete pavement drainage design, similar to HEC-22 in SWMM, however it is a bit of a time consuming process depending on the size of your model. I can go into further details on how to set up the model if you need. Let me know.
Ryb01
