Superscript
Superscript
Superscript
Can anyone tell me how to insert a "squared" digit/symbol into a line of text?
ta
RE: Superscript
I don't use AC but I presume it's the same method as any other app, if not my apologies. You have to use the 'alt' key together with the appropiate number for the symbol desired.
The number depends on the font, for example to get a superscript 2 in Arial, you use the key combination 'alt+0178', you have to use the numeric keypad, not the one across the top. If you want to see what symbols are available, open up character map....Mike
RE: Superscript
I type complexe characters in Word then past it in AutoCAD.  For example Insert, Object, Microsoft Equation Editor 2.0 .  Then in AutoCAD, you can even modify the size of an exponent.  Or you can edit your text and choose other after clicking symbol.
RE: Superscript
Use text stack button in mtext, X^ produces superscript X, ^X produces subscript X, Y^X produces Y over X without a fraction bar.
