A rolled steel part - NX6
Is there a way to create a solid model, starting with a flat pattern, of a part that gets rolled into a cylinder segment?
I really can't figure out an easy way to do it, some of the cut-outs are a bit funky, so simply extruding the cut-outs thru the steel cylinder doesn't work.
We have NX6 "Sheet Metal", but not "Forming/Flattening" or "Aerospace Sheet Metal"
RE: A rolled steel part - NX6
This might not work but, you could try modeling the finished product and then flattening it into a flat pattern.  There is a feature for this in the sheet metal application.
I took cowski's model, edited it so that the sheet metal software could handle it (I created a 'seam' which is exaggerated for effect), converted it to sheet metal and then flattened it (see attached model).
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thanks for all the help.
NX should consider adding something for rolled parts - They have what they need already in there, and they just need to arrange it so it is seemless going from a flat pattern to the finished rolled part.
Perhaps, but in the manufacturing world there is no such thing a 'seamless' part which can be unrolled.
John R. Baker, P.E.
Industry Sector
Cypress, CA
You are right.
In our case we are welding cylinder segments together.
