Dimensioning 3D section views
What is the proper way to dimension 3D section views.  If you take a section as shown in the attached image, how do you properly dimension features on a diameter.  Since your section will be looking at an angle to the top half (not normal) then dimensioning across is obviously not going to produce a diameter but a projected dimension.
I could just use radius dimensions to the centre line, and only on the bottom half of the view, but I was wondering the best accepted way to do this sort of view.  I know others in the company have in the past just dimensioned across the part, then changed the dim values to represent the diameters, which is definitely not correct.
RE: Dimensioning 3D section views
Use an aligned crossection. The upper portion would be rotated into the plane and the diameters look like diameters.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
Thanks, I did not realize the aligned crossection was an accepted practice.  It seemed odd to me as the view produced is not a true projection.
I would reject a section as you originally posted. An aligned section gives a true view of the hidden hole, the directly projected section does not.
Peter Stockhausen
www.infotechpr.net
