ASTM A105 what does it mean?
Hello everybody,
as a german engineer I am not too familiar with ASME codes and standards. In an enquiry my customer requires connection Material acc. to ASTM A105.
What does this mean? Is it the material itself or does this concern the geometry? As a standard we use mat. no. 1.4571 stainless steel pipes 10x2mm.
Is that adequate?
Thanks in advance
Holger
RE: ASTM A105 what does it mean?
ASTM A105, European spec
Thread330-13482
ASTM A105 is an AMERICAN material spec. A.S.T.M. = (American Society of Testing and Materials) A105 is the designation for a forged carbon steel piece, like flanges or weld-o-lets. It could mate up to S.Stl., but would probably not wise to do a dissimilar weld. Good Luck!  ...Mark
A105 is a forged carbon steel, it's like C22.8 except some slight difference in chemical composition especially with Carbon.
In absence of an european equivalent grade, I assimilite it to C22.8.
According to our experience C22.8 can be equivalent to LF2 also (contrary to A105; A105 can work down to -20°F(-29°C) and LF2 to -50°F(-46°C)). DIN specification limits C22.8 to -10°C.
Alternative material to ASME A105
Thread292-13661
A105 is the most common forged material of group 1.1 of materials under ASME/ANSI B16.5 standard (Pipe flanges and flanged fittings), which is the most common flange standard in the industry on the US influence.
So you are right A105 is a material(or manufacturing process of accs.)issue.
B16.5 define material groups in order to stablish a basic compatibility among materials of different manufacturing proceses.
Group 1.1. includes ASTM A105 (a forged carbon steel) and  ASTM A515 Gr. 70 ( carbon steel plate for pressure vessel) for example. So you may find on the "hardware store" a forged welding neck A105 and a A515 70 blind flange, which are basically compatible under B16.5 (resist the same presure and are of similar material). Each group has a correspondent "pressure temperaure rating" as per B16-5.
For stainless steel there are other material groups (which I´m not very used to).
If you are thinking of SS pipes and the customer in A105 CS fittings (common CS flanges) you have to ask yourself if you should clarify this situation (justify the need of SS for pipes, change to CS pipes and get a lot of money from it, weld with care, or see if there was a customer mistake specifyin A105).
The German equivalent for A105 material is 15Mo3. Actually 15Mo3 is even superior since it has some alloying elements, while A105 is a carbon steel forging.
good luck
