Error message
Error message
Error message
Hi guys,
I'm getting an error message when I try and save a part.
Can anyone shed some light on what might be wrong...
"Cannot find NX object from Parasolid tag"
I also get a similar message when trying to delete one particular "Trimmed Sheet" operation.
Part clean up doesn't resolve this.
Any help gratefully received.
Cheers
Jon
Jon S
Medical Design Engineer - Glos. UK
NX 6.0.4.3 / TCE V10.0.3.8.6
RE: Error message
I would run Part Cleanup first.  Also, is this part of an assembly?  If so try opening the individual parts and then save them.  If none of this helps, you will have to contact GTAC and have them look at your files.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
RE: Error message
if it is a single part,
try to import it into a new part
tia
RE: Error message
reg.
RE: Error message
Unfortunately Part Cleanup doesn't work.
Also it has a wavelinked body and sketch which means I can't simply cut n' paste into another part.
Two interesting things of note are ...
1. When I return to this part from the parent wave linked part, this part has turned light grey (as though it thinks its not the Work Part)
2. Teamcenter thinks the part is not Checked In (ie I have the option to "Check Out")
Hmmm -
RE: Error message
File -> new- > modelling template,
file ->import-> NX Part -nothing with clip and paste
RE: Error message
Hi uwam2ie,
I've tried various ways to export the part and re-import but its either unsuccessful or teamcenter doesn't let you do this.
I've got GTAC on the case.
Thanks anyhow,
Job
