You can run a 380volt 50 hz motor on 220volts 60 hz
thread237-251349: Can you run a 3 phase 220v motor on 208v 3 phase?
Anytime you must use a 50 hz motor on 60 hz remember to lower the voltage nuff said
RE: You can run a 380volt 50 hz motor on 220volts 60 hz
I don't agree. Your title is wrong and makes no sense.
