Which materials are best replacement for phenolic cotton- Canevasit
Helo all
We are using phenolic cotton tubes for making of bearing cages for precise spindle bearings. Material designation is CANEVASITE FF 5964 from VonRoll. Are somebody some experiences about use similar materials exactly for this purpose from different suppliers?
than you all
RE: Which materials are best replacement for phenolic cotton- Canevasit
xxtsfxxg
Do you want different makers of the same material such as Tufnol or are you looking a different type of material you can substitute?
B.E.
There is a stamped sheet metal product that will act as a stiff spring to center the bearing in a loose tolerance sleeve.
Firstly I am looking for cheaper substitution of same type material from different supplier
Secondly- if there is some experiences with other materials suitable for CNC machining-except aluminium bronze, brass or aluminium(we are use them curently) with similar performance properties as phenolic cotton e.g. some glass reinforced plastic or carborn fibre composites.
thank you all
Have a look at mcmaster.com for phenolic rod. They stock plenty of grades, and show material properties / pricing.
I do not think xxtsfxxg is in the USA. The first company who's products he mentioned  using, is headquartered in Switzerland.
 The Tufnol Brand, I mentioned in my response to him, is Manufactured in the UK. There is a chinese manufacturer Nova industries Ltd. and I am sure a Google search will produce at least 4 or 5 other manufacturers.
B.E.
