Reusable geometry
Reusable geometry
Reusable geometry
Hi everybody, I am trying to define a sketch that can be used as a reusable item. As far as I get, the sketch is then always applied to the same plane from the initial datum-coordinate-system, but I would like this sketch to be attached to any datum-plane I select. The same behaviour when using an item from the 2D-section library.
Thanks in advance, Bert
RE: Reusable geometry
When defining the UDF (Reusable part), don't include the current sketch datum in the definition.  Then the system will prompt you for a new one when you add it to your model.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
