Welding 09?2? carbon steel to LC1/LC2/LC3 steel
RE: Welding 09?2? carbon steel to LC1/LC2/LC3 steel
Yes.
metengr, thanks for your answer.
Can you please specify more?
Because 09G2S has some different chemical elements than appear at LC1/LC2/LC3, can't they harm the welding?
Any good 70-series filler will work.  09G2S is just a Carbon-Manganese steel.  Look at the spec for SA-106 pipe.
