Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The level of expertise is awesome. The nature in which people respond is professional helpful and not the least condescending. I can't say that for most forums..."
Geography
davidbeach (Electrical)
18 Jan 11 19:21
I have a spreadsheet where certain cells have been given multiple names.  Is there a way of easily showing all the names that refer to a given cell?
In this instance, the spreadsheet deals with relay settings, and for instance zone 1 phase mho distance reach may be named Z1_, Z1P, M1P, and perhaps others.  This is to facilitate macros that can then use the setting as named for that particular relay.  I can see the name that comes first alphabetically in the box at the left end of the formula bar, but is there an easy way to see all the names?
At this point I use ^G (go to) to test to see if a name relates to the cell I think it might.  The Insert|Name|Define method is very cumbersome given that there are probably already 1000+ named ranges and many are mind numbingly similar (great for macros, really bad for skimming through lists), and it is sorted by range name, not by cell.
IDS (Civil/Environmental)
18 Jan 11 19:50
The Range.Listnames method will write a list of names, starting in the named cell, e.g.:
Range("a1").ListNames
It puts the range name in the chosen column, and the address in the next column, so you could either sort on the address column, or read it back into VBA and do what you want with it there.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
MintJulep (Mechanical)
18 Jan 11 20:08
Easy?  No.
You can get the list of names and the range that each name refers to by looping through the Names collection.
Names(index).name
Names(index).refersto
or
Names(index).RefersToRange.Address
Life gets complicated because named ranges can be more than one cell.
You can test for multi-cell ranges with
names(index).RefersToRange.Cells.Count
and you can use Intersect to test if a specific cell is within a range.
So it's possible, and left to the interested student to devise a solution.
Helpful Member!  electricpete (Electrical)
18 Jan 11 20:45
The following will work if you have only one sheet or only names belonging to one sheet. I causes an error when it tests a name from another sheet because intersection doesn't like comparing different sheets.  Prior to the If Not... it needs another "If..." to check if ThisName is within the same sheet at mycell and if not, it should not attempt to do the intersection check.
CODE
Function FindNamedRanges(mycell As Range)
Stop
Dim ThisName As Name
For Each ThisName In Names
  If Not (Intersect(ThisName.RefersToRange, mycell) Is Nothing) Then
    Debug.Print ThisName.Name + "- Address:" + ThisName.RefersTo
  End If
Next ThisName
End Function
(2B)+(2B)'  ?
18 Jan 11 20:46
By the way the intersection idea was of course MintJuleps. I tried to implement it but fell slightly short.
(2B)+(2B)'  ?
18 Jan 11 20:52
OK I think this will work
CODE
        If ThisName.RefersToRange.Parent Is mycell.Parent Then
            End If
        End If
    Next ThisName
End Function
(2B)+(2B)'  ?
18 Jan 11 20:54
Actually it's not set up to run as a function. Change it from a function to a sub and run it from the vba interactive editor and view the output from debug.print statements in the immediate window.
(2B)+(2B)'  ?
18 Jan 11 21:47
Pete - nice function/sub, but I never understand why everyone uses debug.print when there is a spreadsheet available.  I have modified the code to work as a UDF
CODE
    Dim ThisName As Name, NameList(1 To 100, 1 To 2) As Variant, i As Long
    i = 1
                NameList(i, 1) = ThisName.Name
                NameList(i, 2) = ThisName.RefersTo
                i = i + 1
            End If
        End If
    Next ThisName
    FindNamedRanges = NameList
End Function
Doug Jenkins
18 Jan 11 22:03
I built on Pete's work too.  This works as a function, returning a comma separated list of names that refer to the cell that the function is pointed at.
CODE
Function FindMyNames(mycell As Range) As String
    Dim Answer As String
    Answer = ""
   If mycell.Cells.Count > 1 Then
        Answer = "One Cell Only Please"
    Else
                    Answer = Answer & ThisName.Name & ", "
                End If
            End If
        Next ThisName
    End If
    FindMyNames = Answer
End Function
18 Jan 11 22:16
I just tidied mine up to get rid of the nasty hard coded array size :)
CODE
    Dim ThisName As Name, NameList() As String, i As Long, NumRows As Long
    NumRows = Application.Caller.Rows.Count
    ReDim NameList(1 To NumRows, 1 To 2)
    i = 1
                i = i + 1
                If i > NumRows Then Exit For
            End If
        End If
    Next ThisName
End Function
Doug Jenkins
19 Jan 11 7:32
Why output to debug window?
Because it's easier. (one line of code vs 6 lines of code you used to replace it)... outputs right to where I'm developing my program.
Not better, just easier. Thanks you guys for fixing it up to provide a better output.
(2B)+(2B)'  ?
19 Jan 11 12:18
Thanks all, but I seem to be particularly dense this morning.  Where do I put the function (any of them) and how do I call it?  I've tried a few things, but without success.
19 Jan 11 12:46
OK, turns out my problem is the use of multiple sheets and Intersect throwing an error.  Fighting other battles today, I get back to this in a day or two.
19 Jan 11 14:11
The intersection wasn't supposed to execute unless the names were in the same sheet "If ThisName.RefersToRange.Parent Is mycell.Parent Then.."
Apparently that didn't work.  The check assumes that the parent of name refers to a sheet.   That should usually be the case, but maybe for some reason for structure of your spreadsheet it's not?  (parent is workbook... or chart...?).
If you get the error again, try to examine which names are being examined and what are the parents of those names (to figure out why the check for different sheets didn't work).
(2B)+(2B)'  ?
Helpful Member!  yakpol (Structural)
19 Jan 11 16:27
David,
You can do it without VBA.
In Excel 2007 follow menu commands:
Formulas/Use in Formula/Paste Names.../Paste List
In Excel 2003: Insert/Names/Paste... (somewhere there).
It will display a table of all names and their addresses. Sort by addresses to identify the names corresponding to the same address.
Yakpol
19 Jan 11 19:07
Thank you.  Much nicer than the macros.
19 Jan 11 23:28
Another simple approach which seems like it would be helpful in large complicated spreadsheets like you describe is the "trace dependents" feature.
For Excel 2000, with the cell in question selected, select Tools/Auditing/TraceDependents.
It will show arrows to all the other cells in same sheet that reference the selected cell (regardless of whether those other cells refer to selected cell by name or by address).  It will also show an arrow to a little sheet icon and if you click on that arrow you see a list of all the cell addresses in other sheets that refer to your selected cell.
Then Tools/Auditing/RemoveAllArrows to get rid of the arrows
(2B)+(2B)'  ?
20 Jan 11 0:51
In my case, all the references are from other VBA macros, using excel as a way of moving data between programs that know nothing of each other but have export and import capabilities where excel is used to convert the data of the export file to the import file.  Read it, place it, then write it.
Close Box
Join Eng-Tips® Today!
Join Us             Close
