UG Matlab coupling
UG Matlab coupling
UG Matlab coupling
Hello everyone, I've been a user of UG since V12 in 1997 (but in recent years have spent more time in PRO-E and done other non-CAD simulation work).
A brief search did not turn out any discussions about the question I'm asking.  I would like to couple NX with Matlab/Simulink, so that latter would pass parametric data that would be used in NX's Expressions (for example) to generate a solid model from fully-constrained cross section sketch(es) or parameterized surface(es).
After this, I would like to be able to mesh the resulting body for downstream CAE analysis.  All these would be as automated as possible.
Am I asking for too much?
Many thanks in advance.
RE: UG Matlab coupling
Starting with NX 7.5 we now support an interface to the 'Maple' product from Maplesoft (http://www.maplesoft.com/products/maple/).
While I've not done it myself, I understand that if you have an existing Matlab document that it can be read and converted into a Maple worksheet, which can then be linked to the parametric models in an NX part file.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thank you very much for your rapid response, John.  My organization does have licences of Maple but we are primarily a CATIA house at the moment.  I'm trying to make a pitch to get a few more licenses of NX to support our customer in upcoming projects but for my particular issue, I guess I'll have take a closer look at the NX <> Maple <> Matlab (I would much prefer to avoid the intermediate step) or see what can be done with CATIA <> Matlab.
Please keep me informed of any developments on this and thanks again.
Since Maple can access the worksheets of other mathematical 'spreadsheets', such as Matlab, we are probably going to only support Maple as a single solution rather than implement multiple solutions.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I understand.  I mention Matlab specifically because I intend to use the global optimization toolbox in the work I'm doing.  I'm not aware of an equivalent in Maple to do things like multi-objective GA optimization, but I'll search.
Cheers!
