API OR VBA APPLICATION
Does anyone have an api that will create a configuration and write configuration specific properties for it? Ideally it would need to work with a spreadsheet but if someone has the basics I can adapt it to work in excel.
Thanks in advance
Thanks in advance
Jon
RE: API OR VBA APPLICATION
Are you looking to do it while the part is open and active? In an assembly? and what properties? Dimensions? or create your own file properties?
StrykerTECH Engineering Staff
Milwaukee, WI
http://www.stryker-tech.com/
