EO feed line with minimun distance branch line
Dear Sir
There is EO(ethylene oxide) feeding from other plant
to EO surge drum (simple drawing attached in the file).
I was wonder why there is a small brach line on
the p&id, and it was written in the note that
EO should be to provide "minimum dead leg" and any branch line should provide a block valve with "minimum distance"
could you please kindly give me some idea behind this?
Thank you so much.
Thank you so much.
RE: EO feed line with minimun distance branch line
Good luck,
Latexman
