ST3: Scale of views in Draft...unaval to change with drop down...
After placing a view in a draft file, I am unable to change the view scale by means of the drop down scale field.  It only gives me one option, the default scale at which solid edge has chosen.  I can type in a number into the scale view field, and generate a scale that way. (2.0 generates a 2:1 view)  How do I go about correcting this problem.
As I remember, I was able to change the scale by means of the drop down box before.  Certainly in V19, and I recall in ST3 as well.  I have looked for an option that may be checked/unchecked, but as of yet have not found one.
Thanks in advance,
Av8errr
