Measure Tool - Minimum Distance
Is there a way to set the default from "Center to Center" to "Minimum Distance"? I use this more often than the C to C measurement.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
RE: Measure Tool - Minimum Distance
Mac  I feel that the part will be machined (holes) center to center, with the min/max dimension used as a reference dimension only. If you use the min/max dimension as an absolete dimension, you have cut down the center to center plus / minus tolerence in half,making the part harder to make and more costly.Also that also cuts down the diameter plus / minus. I havent tried, but can you set up your templates for the drawings to reflect the min / max you need?
ArtL, he seems to be asking about the measure tool, rather than dimensioning prints. I'd like to know how to change the measuring tool to minimum distance, as well, since I seem to want to know that more often than center-center distance. Of course I still dimension parts to hole centers.
maxh3, exactly what I'm asking.
Mechanical Designer
Try the Instant Measure macro at thread559-241405: Instant Measure.  It doesn't change the measure tool's function, but it does report minimum distance for arcs.
-handleman, CSWP (The new, easy test)
which file do I download?
Mechanical Designer
handleman, that sounds awesome. Do you have any instructions for the installation/use of it?
Just stick that folder somewhere and go to tools-macro-run, make sure the file type is VSTA macros, and browse to wherever you put the file.  Choose SmartMeasure.dll.
Thanks, I got it to work. Is there any way to change the precision to 3 decimal places instead of 2?
I think the source code is there... you will have to find and edit some constant.  Sorry, I don't have time to do it right now.
