How to edit the values of drop down lists?
Hey all.
When in doubt, ask the professionals :)
Can I, in Drafting, edit or add to the pre-defined values of the drop down lists?
Specifically the values of the various drop down lists in the "Surface Finnish Symbol" dialog box. I'm guessing that NX calls a txt file or something similar to get the values. Is it possible to edit these files? If so where are they located?
Any help will be much appreciated.
Mik.
RE: How to edit the values of drop down lists?
Mik,
I believe you can edit the Surface Finish Symbol values from Customer Defaults ... Drafting-->Surface Finish Symbols.
NX 6.0.5.3
Windows XP32
Hey philpd
I found it.
