Titanium alloy grade
Hi, I'm very new to titanium, and just want to know if 6/4 is ok for machining bolts/fixings or is it brittle? I ask as it is easiest to obtain and have been told to watch out for different grades with regards to different uses.
The fixings will be subject to some shocks etc in their use and will be replacing mild steel components.
RE: Titanium alloy grade
http://www
http://www.arp-bolts.com
http://store.mettec.com/
You could use the sources above for non-engine fasteners.
I don't understand your link between work hardening and heat treatment. Heat treatment of fasteners (including Ti-6-4) is most commonly used to increase strength.
