different of supported and floating tank
Dear Friends,
Now Im designing storage tank with Olifin as fluid. Design pressure is Full of water, design temperature is ambient. ID 5.75m and height=7.5m, the code reference is API 650. In API 650 there are supported cone roof type and floating cone roof type, which one is suitable for above parameter design? and what diffenrences of those type?
Thanks alot for your suggestion before.
SPW
SPW
RE: different of supported and floating tank
Many thanks. I have found common practise that floating roof is more safely of burning, caused small space below the roof for fuel vapour (Floating roof elevation based on level liquid). The Floating type is suitable for pressure 1.5 to 11 psi. The pressure of liquid is not exceed the deaed load of roof.(Please correct me!!). But these not found in any code. So my client need justification by standard code. It's my problem.....
Please if any idea ....Thanks before
The diameter you have is probably on the small side for a floating roof. Not impossible.... but probably not as common as floating roofs on larger tanks.
We use floating roofs on oil and fuel type storage tanks mainly.
