size a unit of coating the metal parts with fluoropolymers.
Hello everyone,
I post here on issues that will surely follow on 4 months old.
The goal is to size a unit of coating the metal parts with fluoropolymers.
I do not care that the section on equipment and tooling.
This is to size the new unit EPF see other ideas on the previous phases.
So if you have any links above assumptions, ideas you're welcome.
Of course, I will overnight information processed, calculations
RE: size a unit of coating the metal parts with fluoropolymers.
keniz,
You question is a little fuzzy.  I am assuming that you are trying to put down teflon on a metal substrate?  Do you want to spray the teflon on or do you want to grow it on the surface?  How are you putting the materials in place-conveyor, metal racks?  What is your required total through put for the production?  This will determine some of the equipment sizing requirements.
Rich......viking2
Richard Nornhold, PE
http://www.personna.com
The goal is to size a unit of industrial coating, certainly know of the production capacity will determine the size of this unit,
I just want to have a step has to follow to establish this study .. thank you for your reply.
the objectif is the constructing a layout plan of a coating unit
