Lock Scale for Solidworks
ProE has the Lock Scale feature and the Sketcher tool. this allows changing all dimensions to scale when you change just 1 dimension. Is there a similar thing for Solidworks?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Lock Scale for Solidworks
http
This allows uniform and non-uniform scaling, but creates a feature in the history (Feature Manager), and can also create confusion when editing a feature created before the Scale feature.
Another method is to use the ModelRescaler macro from http
This applies a scale to the actual feature sketch dimensions, and does not create feature in the FM. So no confusion when editing, but only uniform scaling is available.
THe idea of this is that you build the model to 1:1 scale, if you need to make it bigger then you can use the Scale feature, or you will have to roll back the tree and change each feature to the proper size. I am afraid scaling the dimensions could potentially cause sketch realationship problems/errors and cause you far more harm than good.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
www.scottjbaugh.com
