Select Elements Overlapping Text Automatically
HI!!! I need some help... Can somebody tell me what I need to do in Microstation so that I can select all the elements that overlaps or touches by a text....?
RE: Select Elements Overlapping Text Automatically
Bob Mecham
Training | Consulting | Programming
www.EnvisionCAD.com
Facebook: http://www.facebook.com/EnvisionCAD
Twitter: http://twitter.com/envisioncad
Youtube: http://www.youtube.com/user/envisioncad
Is there any other way I can do this in a more speedy way.
Any advice will do
Couple options for you. If you are using a newer version of MicroStation V8 you could create a Text Style that has background enabled. This will allow you to place text and have it appear like the elements behind the text are clipped without actually clipping the elements.
Option 2 would be to download CivTools from Bentley Communities website and use the label contour command which will place the text and clip it at the same time.
See screen shots...
HTH,
Bob Mecham
www.EnvisionCAD.com
