Sea Water Intake Lines
hi all, i'm mechanical engineer at bp operation in tangguh LNG, papua. i wanna ask a question about sea water intake line material, is it safe if we are using the GRE pipe,or I should use a super duplex material, and does anybody has an information about the price of super duplex material, thx
Bilal Adi Akbar
Mechanical Engineering Challenger
BP Tangguh Operation
RE: Sea Water Intake Lines
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
What diameter, length and pressure are you dealing with?
Plymouth Tube
Bilal Adi Akbar
see this paper, maybe it can help:
ht
S
Corrosion & Rust Prevention Control
Steve Jones
Bilal Adi Akbar
In my experience 30°C is the limit for the application of Superduplex (PREN >40) in seawater.
S
Corrosion Control
Steve Jones
Bilal Adi Akbar
It was not a lucky guess but just a simple suggestion based on the assumption that if the service is a Sea Water Intake Lines then the operating temperature should be quite "low"...
and as i said it was just a suggestion not a material selection report..
have a nice and lucky day
S
Corrosion Control
My point was: a recommendation without knowing the service conditions is a lucky shot. Tangguh is in tropical waters and will be very close to the generally adopted limit for super duplex. In all probability, the seawater may, on occasion, exceed 30 deg C.
Best to get complete data before making firm recommendations.
Steve Jones
Experience is something that is not possible to teach.. You're right, i didn't think that in some areas of the world the seawater temperature can reach that values...
thanks for your help
all the best
Vitt
Corrosion Control
