genetic engineering
genetic engineering
genetic engineering
I have completed  biotechnology course.hence I want to know much about progress in biotech and medicine field.what types of reactors are used for culuturing better quality of drugs.
RE: genetic engineering
If you finished the biothech course you should know that the quality of the drugs do not depend on the type of the reactor but it depends on the procceses wich are after fermentation. Like filtration, chromatografy, etc. For example in procces of amylase enzym you have got 5 other processes after the growth of culture before you obtain the final product.
Best regrets
Sergiusz
That’s not even a question that I would expect from a person that have just finished a course of biotechnology.
Like sergiusz said the quality of the drug/product depend of the downstream process selected, and the downstream process depends of the use to give to the drug/product.
What you can vary changing the type of reactor or changing the MO is the quantity of  drug/product in your media if the MO.
Beutiful thanks i needed that
