Sheet-metal loft bend
Hello
I have a rather simple sheetmetal part I've been trying to model for some while now. The problem is the transition from a square scetch to a circular, and then to be able to continue using other features like edge flange. See attachment...
I've tried loft bend, and converting a regular model to sheet metal.
I'm using Solidworks 2009 for this.
Thankyou for any helpful tips.
RE: Sheet-metal loft bend
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
The closest i can get to the shape i want, is with using the sheetmetal loft bend, the problem is that the edges of this shape is not planar, therefore using features to further build on this is not possible.
I attached a a part that shows the shape i want, the problem is i cannot put a edge flange at the flat end, and the extended circular area is not merged with the other body. (the dims are not important)
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
StrykerTECH Engineering Staff
Milwaukee, WI
http://www.stryker-tech.com/
Thanks anyway for the effort!
