HELP to wrap a sticker around a box with NX6
I need to wrap the sticker around the 4 planar faces and 4 blends of my box.
Have a look at my part
What's the best way with NX6 ?
Thanks in advance
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.com
RE: HELP to wrap a sticker around a box with NX6
I created a single ruled surface around my box with a little offset.
Then I was able to create a visualization material (instead of decal) with Texture Space Uv
It's nearly good but the sticker is inverted !!!
I tried to change the direction to build my surface and also the normal without any success.
I have attached a zip file with prt and jpeg files
Does anybody have an idea ?
Thanks in advance
Didier Psaltopoulos
In fact, I had planned to do this. But is it a bug or the right way ?
Didier Psaltopoulos
I would say it is a known "limitation"...
You should write an Enhancement Request about it.
( And ask for other enhancements on the UV mapping...
You can reverse both curve 1 and curve 2 in the ruled surface, then the image is as expected.
Tomas
The result is not good by reversing both curve 1 and curve 2
Did you try ?
Didier Psaltopoulos
the result is not good, but the image is reversed...
( see image)
You send me the image from NX menu not from the result !!!
Didier Psaltopoulos
Attached is two screenshots of the reversed image.
NX 6053, MP4, Win Xp 32.
the reversed.png is a "studio display mode" screendump
the reversed_HQ_rendered.png is a screendump of a rendered image.
Tomas
Here is a zipfile with both images.
Tomas
Thanks in advance to send me also the part file to understand why I didn't succeed ?
Didier Psaltopoulos
I have succeeded by reversing curves sense and order.
Didier Psaltopoulos
