softening properties of zinc
I am looking for a way to soften zinc to make it as close to the softness of lead as possible. This is not for structural use, it is for simulating lead without the hazards.
any ideas?
thanks
chris
any ideas?
thanks
chris
RE: softening properties of zinc
ht
Adriaan.
I am a Mechatronics Engineer/part time Master's student from South Africa.
www.martin-electronics.co.za
thanks
thanks
You could try bismuth or tin or alloys of either as lead substitutes if softness/malleability is what you're after, but you're not getting away without this costing you substantially more than zinc will- or lead for that matter.
Any of these materials will be very easy to recycle if "test tool marks" are made in specimens that are then disposed of.
