Engineering iPad apps
Hey guys,
Our company recently bought us iPads. I was hoping that some of my fellow engineers would know about some good apps that help out with work. I'm a structural engineer, but I'm really looking for any app (free or otherwise) that has been helpful in the engineering field. It could be as simple as a calculator or sketch pad to something that breaks down forces and helps with load take down. Even if it's not structural related, I can probably pass it on to the MEPT guys I work with.
Thanks.
Thanks.
RE: Engineering iPad apps
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
John R. Baker, P.E.
Industry Sector
Cypress, CA
Darren
http:/
No idea how it works since my company does not supply us with IPads
T.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Re: FEA on iPad - maybe you saw it in tobbe's post just a bit higher up on this page?
Hope this helps!
Ben Loosli
What spreadsheets are you guys using? I need to translate some basic hydrology spreadsheets over to iPad.
I've found GoodReader to be pretty invaluable if you want file management capabilities.
Excellent!
Better still, it also works with Android!
If anyone knows of a good spreadsheet app for Android I'd love to hear about it. The two I have tried so far (Sheet to Go and E-cell xls Pro) have beeen less than impressive.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Have you looked at Androffice? I haven't, but it looks reasonable. I have a Blackberry Storm (blech!) and I use DocumentsToGo on occasion. It works "ok" for opening and looking at spreadsheets. I'd expect that any spreadsheet app is going to be a bit crippled due to the lack of a keyboard and mouse.
http:
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Doug Jenkins
With Numbers, each tab is not a simple field of cells. Each tab is a blank page into which you can drag *objects* that are tables, or pictures, or graphs, etc, and you can format each table individually. Cells in one table can reference cells in another table or another tab easily.
Then when you create a new tab, you have the option of either making another blank page into which you can drag more objects, or making a "form" just like an Access or other database form, and reference that form to any of the tables you've already created. So it works just like a database too.
Very, very slick top down design for a piece of software. Pretty intuitive on iPad too. It's not backwards compatible with Excel though, because it can't be, because it's got a better overall topdown design. I'm very impressed.
If only Macs weren't so ungodly overpriced and unintuitive to use and completely lacking in support of the other software I use, I might switch. Numbers is slick.
It's new, it's free, it's everything you want in a field note system. You snap photos, attach them to notes, which are then georeferenced to your GPS location while snapping the photos, and you can email the note as a KMZ file so recipients can pull it up in Google Earth, where they see a thumbtack of your location when snapping the photo, and see the photos as well.
Very impressed.
h
John R. Baker, P.E.
Industry Sector
Cypress, CA
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
And it refreshes in place correctly, but can't be pasted into a new window or tab in IE. If you click the link in Chrome or FF, it should work.
TTFN
Chinese prisoner wins Nobel Peace Prize
tg
He replied about 5 minutes later with the following link:
http://galaxytabhacks.com./
It appears people are already 'taking it apart' and the one link loads a Linux variant Ubuntu... quite pleased with the tablets (not phone capable).
Dik
I've been personally developed the MUTCD app, TurnCount, and TurnCount Lite apps for the iPhone and iPad. I've been working on mobile apps for about 2 years now. The TurnCount app can replace a count board and is compatible with JAMAR's PetraPRO. The MUTCD app simplifies finding everything in the 2009 Federal MUTCD, especially signs.
Gary
www.trafdata.com
So now the question of this thread is of interest to me: what kinds of cool stuff (engineering calcs) can I do with this new toy ?
I could not read the link of the 5 ASME Apps even after cutting/pasting. Can anyone list the 5 Apps here?
I remember the free Mathcad-like program "smath" is supposed to work with handheld devices. I was disappointed to read on their forum that Android is not among those (I don't think iPhone is either but you might want to double-check if you have one of those) and development of smath for Android is "paused".
I am also interested in spreadsheets. I tried the Quicksheet that came pre-loaded. It was clearly not suitable to programming. The odd thing is that if you enter a formula you find yourself in a keypad entry screen with absolutely no way to "point" to other cells to make them part of your formula. (I guess you could type in the cell address, but that seems silly to me). I guess if there's a way to get spreadsheets from PC into smartphone, it would make a lot of sense to use spreadsheets developed on pc and transferred to smartphone, rather than developing them on the smartphone. I'll be fiddling around with my Android to see if there is a way to do that....I'm still a newbiew in handling files on this thing (In meantime, does anyone know if Quicksheet reads normal xls files?).
There is one App that wasn't mentioned in this thread that should be of interest to some engineers particularly the older ones. Droid48 = free program for Androids to emulate HP48 handheld calculators. I spent a lot of time using and programming with HP41CV many years ago.... not all by choice... partially due to instructors who I'm convinced had a bit of a sadistic streak in requiring us to do repetitive numeric calcs by handheld calculator which were much better suited to PC's already available at that time. But there is some good that came out of that traumatic experience after all.... the HP48 syntax seems identical (for my purposes) to the HP41CV syntax that was beaten into my memory. Also, there are free manuals for the HP48 that can be downloaded on-line, and many many free programs and libraries available on-line. And writing programs yourself is pretty easy if you've already used one of those calculators. How to transfer programs between PC and Android is again something I'm not sure about yet.
I have to admit though, it's somewhat weird and ironic that I am considering it a useful tool to be able to use a 1.6 Ghz 16GB 2011 device to emulate a 128k ram, late 80's device.
(2B)+(2B)' ?
Doug Jenkins
At first I thought the basic strategy would be:
1 - Take your key often-used spreadsheets from pc.
2 - Transfer to google docs.
3 - Open in Android and see what doesn't work.
4 - Fix the version that lives on google docs to be compatiable with Android.
Steps 1 thru 3 might be skipped to varying extends if you already know limitations of google docs on Android.
I tried several spreadsheets and all opened on Android, but none of them worked to my satisfaction yet.
I have one very close to working, all I needed was drop-down data menu using data validation. Google docs says they have that, so I added it to the google docs version using my pc. Works fine on the pc. On the Android, it puts a little foot-note next to the cell which tells you to input only values from range B5:B9 (where my example values lie. No help there to save typing.
As you probably already discovered, vba doesn't transfer over. Neither does the analysis took-pak complex math functions.
I think it could still be useful. The strategy would have to be:
Build spreadsheet from ground up (on pc) with the limiations of Android in google in mind.
(2B)+(2B)' ?
(2B)+(2B)' ?
