Estimating Gas Flow Rate from Produced Water Degasser
I would like to estimate gas evolved in a produced water degasser. The degasser is located on an offshore platform. Produced water is fed from the the a three phase production separator, which operates at a pressure of 15 barg. The water then enters the degasser where it is degassed, with any evolved gas being routed to flare.
My query is, how can i estimate the gas flow rate in the degasser?
Normally, i would use a process simulator to estimate gas / water separation. However, simulation in Hysys suggests no gas will be evolved in the vessel.
RE: Estimating Gas Flow Rate from Produced Water Degasser
http://antwrp.gsfc.nasa.gov/apod/astropix.html
